aquamanlr Posted April 22, 2010 Share Posted April 22, 2010 I needed to clear the workbench for a couple larger projects, so I built this lightweight grinder stand. Any comments welcome. Sorry about picture size, I will resize the next one. LeeRoy Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 22, 2010 Share Posted April 22, 2010 Looks like a basic grinder stand alright. The only things I do differently is to make a little table for the grinder to sit on with a little rim around it. That way I can lay items, say drill bits, on it without worrying about them rolling off or going looking when I finish one and am ready to start on another. The other thing I do differently is make a hanger for a quench can. Depending on the shape of the leg or legs, I place the water can either on the center post under the table or on the left leg so it's out of my way being right handed I'll do any out of position work on the right wheel. A four legged stand like yours could use a shelf half way to the floor to store things and add stiffness the stand. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
aquamanlr Posted April 22, 2010 Author Share Posted April 22, 2010 Frosty I like your improvements, I will most likely follow-up with them. LeeRoy Quote Link to comment Share on other sites More sharing options...
Frosty Posted April 23, 2010 Share Posted April 23, 2010 Frosty I like your improvements, I will most likely follow-up with them. LeeRoy Why thanks LeeRoy but you might want to give em a try before saying they're actually "improvements." In truth, they're things I've gradually added over the years and decided to keep. Mostly as a result of being too lazy to look farther than necessary for something I know I'm going to need next. Also, I haven't build a grinder stand with a lower shelf however I know it could be darned handy because the shelf under my bench mounted grinder sure is. I keep extra wheels, the stone dresser and the necessary wrench and screw driver there. I must say though it is gratifying when something I've adapted sounds like a good idea to others. Frosty the Lucky. Quote Link to comment Share on other sites More sharing options...
