Dillon Sculpture Posted April 21, 2010 Share Posted April 21, 2010 Finally got some time to try some dies out, 3" ball and 3 1/2" ID pipe. Tried the 1/4" steel plate first, not sure why I always pick up the largest piece I find first. Some 1/8" steel, and 1/4" aluminum, two hits for the 1/4" aluminum. I do have concern about the return of the ram, If you impact something it will return nicely, but operations like sinking or drifting I have problems with the return of the ram. There is a large spring that moves the contact wheel into the flywheel and I have pretty much fully adjusted it, I may need a heavier spring made unless I'm missing something? Quote Link to comment Share on other sites More sharing options...
Randy Posted April 23, 2010 Share Posted April 23, 2010 It's funny to see this. I just did the same thing in order to make the 2 sides of some bird heads I had to do for a bridge railing. Punched into a hollow block and cut off the half round to make half of the birds head. Quite the time saver. Quote Link to comment Share on other sites More sharing options...
Dick L. Posted April 23, 2010 Share Posted April 23, 2010 Randy , Those are great examples of birds !! Very nice! Thanks for taking the time to post them. Dick Quote Link to comment Share on other sites More sharing options...
Nakedanvil - Grant Sarver Posted April 26, 2010 Share Posted April 26, 2010 For operations requiring stripping I like to adjust the thrust bearings where the screw joins the ram to allow a little slop. That way the flywheel has a chance to get moving a little before it tries to strip. Quote Link to comment Share on other sites More sharing options...
Dillon Sculpture Posted April 27, 2010 Author Share Posted April 27, 2010 Thanks Grant, I'll give that a try. Quote Link to comment Share on other sites More sharing options...
