Ted T Posted April 15, 2010 Share Posted April 15, 2010 I am requesting help to identify approximately what year my Trenton Anvil was manufactured. TRENTON Anvil Markings 1. Found on the front Foot: 200 21 0525 Note: There was NO “A” found in the serial number When we weighed the anvil on bathroom weigh scales, it read about 205 lbs. Note: The scales are not exact and we had to place some boards in the scale for the anvil to fit. So, 200 pounds would be very close! 2. On the Bottom of the anvil, it has an Oval (Cupped out) shape with the number 41 In the center which were “Raised” numbers from the casting process. 3. On the right side, there is a horizontal diamond shape with the word “TREXION” stamped in it. Note: There is no other marks such as (USA) or (GERMANY) found under it. Quote Link to comment Share on other sites More sharing options...
piglet_74 Posted April 15, 2010 Share Posted April 15, 2010 I looked in the Postman book, the A disappears by about 1913 and by the late 1930's the N started to look more like an X. If the 200 is the weight then the serial 210525 would put it between 1943 and 1945. Hope this helps, Rob. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted April 15, 2010 Share Posted April 15, 2010 Made in Columbus Ohio Phil Quote Link to comment Share on other sites More sharing options...
Sask Mark Posted April 15, 2010 Share Posted April 15, 2010 Please post pictures if you have a chance Ted. I think Trentons are the best looking anvils. Quote Link to comment Share on other sites More sharing options...
Ted T Posted April 17, 2010 Author Share Posted April 17, 2010 Thank all of you for responding. I needed your to help, and you helped!!!!!Thank you again! Ted Throckmorton Quote Link to comment Share on other sites More sharing options...
