March 30, 201016 yr A little bit of new work. I've never done rings before, but decided to give it a shot after I was asked if I could. They are all from either 1/8" or 3/16" round. I used a coal forge- And had to keep a CLOSE eye on things to avoid burning these up! I had a couple of little mishaps along the way. If I were to start making a lot of these, I think I'd use a gas forge The finish is soy-based wax. I think that I am going to try polishing a few up, too. And, perhaps some stainless as well. -Andrew
March 30, 201016 yr Very nice work. I like the small, tedious pieces. I think the attention to detail in the tiny stuff helps me a lot when I move to larger work. The old "brass brush at a black heat" will give those an interesting effect as well. Don
March 30, 201016 yr That is some down right righteous work! Nice organic tendril, you da man! :blink:
March 30, 201016 yr sort of work that the 1 firebrick forge is well suited for, can do them in the basement during bad weather. Think of trying it out with copper grounding wire and then silver! Both hot forge a lot alike but copper is a lot cheaper to make your mistakes on!
