Glenn Posted September 12, 2006 Share Posted September 12, 2006 What tools do I need to get started in blacksmithing? The question is intended for the newbie plus level of blacksmithing, and should be considered "real tools" to replace the starter set of make do items he wants to replace. Anvil - something in the 100-200 pound range Hammer - how many, what style, straight pein, cross pein, slash or diagonal pein, ball pein ? Forge - depends on the fuel available in his location Tongs - how many and what configuration? And what other tools should be put on the list? Quote Link to comment Share on other sites More sharing options...
HWooldridge Posted September 12, 2006 Share Posted September 12, 2006 A vise is a must have - you really can't do a wide range of work without one. Hammers are somewhat personal. After almost 25 years, I only have 7 or 8, plus 3 sledges. Some smiths have 50 or more and that's OK. At least one ball peen and the rest can be cross peen. At least one cross peen hammer at 1-1/2 lbs and another at 2-1/2 to 3. Bolt tongs with box jaws are most universal. Jigs can be built to hold flat iron securely but flat jaw tongs are almost useless for most work. Some variety of anvil hardy tools and some top tools are needed but will depend on the smith. However, you need a good hot cut - both for the hardy and as a top tool. I also have a round drift I use constantly - small end is about 3/8", large end is 1-1/4" - tapered uniformly for 8 or so inches. Quote Link to comment Share on other sites More sharing options...
the_sandy_creek_forge Posted September 12, 2006 Share Posted September 12, 2006 Ball pein hammers as far as ball pein hammers go, check out the five piece set from harbor freight. They take a little bit of file dressing, but they've held up pretty well for me. i think the sizes are 8 oz. to 32 oz, and they cost around ten dollars a set. great for the starter and the advanced starter. Quote Link to comment Share on other sites More sharing options...
the_sandy_creek_forge Posted September 12, 2006 Share Posted September 12, 2006 sorry, shoulda added this to the other one. tongs: along with the box jaw/universal jaw bolt tongs, i recommend two sizes of pickup tongs. I have a set that have three "waves" to them (therefore three sizes of openings in the jaws) that work well for holding punches and some sizes of round stock when upsetting, as well as picking stuff out of the forge. IMHO, a smithin' magician/ guillotine tool is indespensible for alot of the work I do (and there are plenty of plans out there) This was one of the first tools that I made, and I use it on a very regular basis. This along with the fact that it can be made by anyone with a welder, drill press , and chop saw puts it right up there at the top of my list. There are so many different dies that can be made for the guillotine tool that I've never bothered buying/making their "real" counterparts (Ex: round and square swage dies , slitting chisel dies , flatter dies , side set dies, fullering dies , and various shaping and decorative dies). and best of all you don't need to bribe your buddies with beer to get them to swing a 10 lb. hammer for you, cause the tool lets you do the swinging :) Quote Link to comment Share on other sites More sharing options...
son_of_bluegrass Posted September 13, 2006 Share Posted September 13, 2006 Some sort of hold-down. Hammers: at least one sledge or hand-sledge in the 3-5 lb range something around 1/2 lb the following faces/piens in whatever combination in a weight comfortable to use for extended periods of time flat, crowned, ball, straight, cross (right and left diagonal can replace straight/cross) it never hurts to remind on safety equipment ron Quote Link to comment Share on other sites More sharing options...
Swamp Fox Posted September 13, 2006 Share Posted September 13, 2006 Get some safety glasses, ear plugs, and an apron. Then use them. Add comfortable steel toes shoes when you get a chance. Quote Link to comment Share on other sites More sharing options...
