Mark Wargo New2bs Posted January 3, 2010 Share Posted January 3, 2010 Got the Champion 400 cleaned out, lubed up, and painted. She turns very nicely. With the air exhaust covered, the handle makes 3 rotations after you stop cranking. Sadly, it seems that the handle shaft was peened into place. Anyone have any suggestions for how to re-handle it? Mark Quote Link to comment Share on other sites More sharing options...
NRunals Posted January 3, 2010 Share Posted January 3, 2010 That looks really nice, good job cleaning it up. For the handle you could cut the existing one off, make a new one and attach it how it was originally attached. Quote Link to comment Share on other sites More sharing options...
bsiler Posted January 3, 2010 Share Posted January 3, 2010 Looks good. I have one that I need to replace the handle on also. It seems to be peened too. How were they put on originally? Screwed on maybe. How did you go about cleaning? Wish I had the original legs for mine. Anyway, Very nice clean up Thanks for showing it Billy Quote Link to comment Share on other sites More sharing options...
zampilot Posted January 3, 2010 Share Posted January 3, 2010 What did you use for lube? Quote Link to comment Share on other sites More sharing options...
Mark Wargo New2bs Posted January 3, 2010 Author Share Posted January 3, 2010 Well, since I was mainly cleaning it in the kitchen while my wife recovered from a hysterectomy, I used Simply Orange and Dawn dishwashing liquid after the initial spray down with DW-40. I used a wire wheel on my dremel and a larger one on my drill to clean up the exterior. I used a wire brush on the interior. For some of the tight spaces inside I ended up using a dental pick. Currently it's lubed with motor oil. Each of the three legs is in some state of rust deterioration on the bottom, but otherwise it's in great shape. Quote Link to comment Share on other sites More sharing options...
