buell508 Posted January 2, 2010 Share Posted January 2, 2010 I have a question on chimney,the building is atached to a 2 story barn.will I have to make the chimney taller than the 2 story or only taller than the peak of the building it's in? Thank you Quote Link to comment Share on other sites More sharing options...
NRunals Posted January 2, 2010 Share Posted January 2, 2010 i would say at the very least make it rise two feet above the peak of the building it's in. also the larger the diameter of the pipe the better Quote Link to comment Share on other sites More sharing options...
Dragons lair Posted January 2, 2010 Share Posted January 2, 2010 Would depend, Is it 2 peaked roofs or the common peak on the barn with a leanto shed on the leeward side. Also where is the chimmeny in relation to the highst peak? Ken. Quote Link to comment Share on other sites More sharing options...
petere76 Posted January 2, 2010 Share Posted January 2, 2010 Buel508, The chimney system is a mass flow device. You want gas velocity and you need to minimize reistance to flow in the piping. The heat of the gas and the configuration of the hood structure and the the smoke shelf start the velocity. Research the smoke shelf venturi concept so you understand the principle, this is important. The number of directional changes (elbows) and the structure at the top (cap) of the chimney add to the loss of the velocity and hence the effectiveness of the system in exhausting the gasses. Use the largest diameter pipe as is practical, 10 inch seems to be the most popular and reasonable price wise. In regard the height of the stack above the nearest peak. 10 feet is an acceptable lateral distance from the closest peak where you do not have to worry about going above the peak line. Anything less than an 8 pitch roof is more forgiving in regard proxmity to the peak. Shed style roof systems, popular in warmer areas, almost have no effect on the draft. Conversely, the steep pitches (> 8-12) typically found in new England have a more pronounced effect on draft. Be guided accordingly. Spend some time doing the research on the stack and the hood configuration, these are the parts you have control over, it will serve you well. Quote Link to comment Share on other sites More sharing options...
buell508 Posted January 3, 2010 Author Share Posted January 3, 2010 thanks for all the info Quote Link to comment Share on other sites More sharing options...
TimB Posted February 5, 2010 Share Posted February 5, 2010 You want your chimney to terminate two feet above the point where a ten foot stick held horizontal, would contact both the roof and the chimney at the same time. If you come to the peak of the roof before you reach the ten foot between point, then go just two feet above that. For some reason the pitch of the roof messes with the draft below that. That is industry standard in furnace installations in homes and such. I moved into a home where the wood stove chimney did not meet this standard and I tried outsmarting the physics but I just couldn't get my stove to draft till I rebuilt the chimney to code. Quote Link to comment Share on other sites More sharing options...
pkrankow Posted February 5, 2010 Share Posted February 5, 2010 For short buildings, 12 feet minimum rise of total chimney is a good idea. Might be code for wood stoves too. I've read it in a lot of places lately. Phil Quote Link to comment Share on other sites More sharing options...
