sqeezplay Posted August 18, 2006 Share Posted August 18, 2006 one of my freinds has been working on a file knife for a long time, it's very cool, so now we're down to putting in the rivets in the handle, the only problem is we can't seem to get through the file. so, what speed should i have my drill press on , and what kind of drill bit should i use? thanks, M Andrew D God bless Quote Link to comment Share on other sites More sharing options...
Jeff Mack Posted August 18, 2006 Share Posted August 18, 2006 Have you annealed the file? If not, you will want to. As it comes, it is likely too hard to drill. Quote Link to comment Share on other sites More sharing options...
Frankw Posted August 18, 2006 Share Posted August 18, 2006 If you have a drill with very slow speed you could try a new masonry bit and keep it well oiled I have had good susses with this method. Drill the pilot hole with the same type of bit also. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 18, 2006 Share Posted August 18, 2006 As they probably don't have access to heat treating equipment they probably do not want to anneal the file! I sure hope they drew the temper on it in their oven though---if not when they drop it it will probably break in several pieces. Drilling hardened steel---if you must, use a solid carbide twist bit make a dam for coolent and use a *GOOD* steady drillpress, Drilling in a hand drill will probably break more expensive bits that you want to! I'd suggest figuring a way to do the handle using epoxy to hold the tang, much more likely to get a good using knife that way And be sure to find out how much they drew temper on the blade *FIRST* Thomas Quote Link to comment Share on other sites More sharing options...
Woody Posted August 19, 2006 Share Posted August 19, 2006 you can draw the temper on the handle portion of the file knife by either imersing the blade up to the handle in water or sticking the blade through a potato up to the handle and then heating the handle with a propane torch until it is dull red and then let it air cool then the handle should be soft enough to drill. Jigging putty will also work in this application. Woody Quote Link to comment Share on other sites More sharing options...
Jeff Mack Posted August 21, 2006 Share Posted August 21, 2006 That potato idea is cool. Never thought of that. Quote Link to comment Share on other sites More sharing options...
Nolano Posted August 21, 2006 Share Posted August 21, 2006 I like Woody's idea, but I would heat it to a dull red then stick it in wood ash or vermiculite if you have any, as it will be easier on your drills. if you dont, normalizing it should still work. Quote Link to comment Share on other sites More sharing options...
Pine2play Posted September 13, 2006 Share Posted September 13, 2006 Great idea--nice baked potato for a snack afterwards. Quote Link to comment Share on other sites More sharing options...
