SBuzek Posted July 7, 2009 Share Posted July 7, 2009 I forge welded a piece of 3/4" cable to day and wound up with a bar 1/4"X3/4"X15" in length.My question is how do I get a wider bar, should I cut and stack and weld it together again and go from there or is there a better way. Thanks Stan Quote Link to comment Share on other sites More sharing options...
adamj Posted July 9, 2009 Share Posted July 9, 2009 i would just fold it over and weld it same as cutting it without having to cut it. and use a cross peen to widen it easier Quote Link to comment Share on other sites More sharing options...
Rob Browne Posted July 9, 2009 Share Posted July 9, 2009 Yep, just fagot weld it then draw it wider, not longer. Quote Link to comment Share on other sites More sharing options...
JPH Posted July 9, 2009 Share Posted July 9, 2009 SB: If you forge in a decent edge bevel you can get a 1 3/16" to 1 1/4" wide blade out of 3/4 x 1/4" stock no problem..wider if you are really good at it... JPH Quote Link to comment Share on other sites More sharing options...
