July 6, 200916 yr This is my 209lbs O'Dwyer Anvil. These are cast in Australia. I need a better anvil stand. I am thinking about a metal bucket filled with sand or the 2" solid top tripod leg stand. I am looking for some mass and stability. I would appreciate any input.
July 6, 200916 yr Nice looking anvil. Is the notch on the right side, just before the cutting table stock? What is that Hook that looks like it is bolted to the bottom of the horn? I would get a larger round of hardwood for a base if possible. There are lots of other ways, but I like wood.
July 6, 200916 yr I have use wood but it sat in one place for so long it started to get termites so I welded one up out of some large box tubing, 12"x18", with a 3/8" base & top plate. Before I welded the top plate on I filled it full of sand. It is solid and quiet like wood. The ring is almost dead but is a booger to move. I also welded 3/8" square rod to the top plate to clinch over to hold the anvil in place.
July 7, 200916 yr Author Thank you Sweany and Bentiron. It appears that I should have searched. Thank you both for your responses.
July 7, 200916 yr My anvil stands are made from 1-1/2" plate with three legs-2 at the horn end, 1 at the tail-placed at 22-1/2 degrees. The front legs are splayed out a bit. I used 3" box tube for the legs. I then bolt the anvil down with bars across the feet with silicone under-let the silicone dry before bolting down. Really deadens the noise factor. Adds a lot to the overall mass and stability. I saw Hofi use this sort of stand and liked it. I like to get close to the anvil-already had 1 back surgery-don't want another- and it is a lot more comfortable for me to work that way. Mark Emig
July 9, 200916 yr I use a hunk of log similar to what you have, but bolted it to the concrete floor with some "L" brackets. That kept it from running away from me. Hurts like a bugger if ya kick it though..
July 9, 200916 yr Mate, if its an Aussie anvil then a dirty great lump of ironbark is what ya need (Ironbark is a very hard and heavy Australian timber.)
