tyro Posted June 22, 2009 Share Posted June 22, 2009 I'm thinking of making the vise repair as described in the blueprints section.Can someone please describe how to braze the thread to the nut? Thanks. Quote Link to comment Share on other sites More sharing options...
Sam Thompson Posted June 22, 2009 Share Posted June 22, 2009 It's pretty well described here: BP0060 Rebuilding a Vise | Blueprints 000-100 Quote Link to comment Share on other sites More sharing options...
tyro Posted June 22, 2009 Author Share Posted June 22, 2009 It's pretty well described here: BP0060 Rebuilding a Vise | Blueprints 000-100 The problem is I don't know what spelter is or what flux to use. Is spelter ground brass or just brazing rod? borax flux or should I get brazing flux?. I'm pretty confident I can make the thread.........Thanks Quote Link to comment Share on other sites More sharing options...
Sweany Posted June 22, 2009 Share Posted June 22, 2009 The easy wayWholesale Tool - Search Results for acme thread Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted June 22, 2009 Share Posted June 22, 2009 Spelter is brass used for brazing. I'd go with a brazing flux from your local welding supply shop. This is rather a tricky project for a first go at a new to you process! Quote Link to comment Share on other sites More sharing options...
Sam Thompson Posted June 24, 2009 Share Posted June 24, 2009 The method in the BP involves a lot of heat in a large lump of metal. If you are not used to handling this kind of thing or don't have the right tools then it would be very difficult and dangerous to try this. Quote Link to comment Share on other sites More sharing options...
