ironantlerforge Posted June 14, 2009 Share Posted June 14, 2009 Hey guys, I have a 55 gal drum full of vinigar that I use to remove rust and scale from steel. I have a lid on it but this drum has several holes in it so I can lay rod to hang projects into the bath. I'm wondering if I keep this vented drum outside, under a roof, if the vinigar will loose any of it's rust removing properties? I don't see why it would but I thought I would put it out there. Thanks! IAF Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted June 14, 2009 Share Posted June 14, 2009 Google has lots on evaporation of vinegar Quote Link to comment Share on other sites More sharing options...
Charlotte Posted June 14, 2009 Share Posted June 14, 2009 Vinegar will over time break down when exposed to air. But the water will also evaporte so better outside than inside. Quote Link to comment Share on other sites More sharing options...
Glenn Posted June 15, 2009 Share Posted June 15, 2009 Cover the top of the vinegar with polyethylene balls or pellets to act as a floating lid. You can still get parts in and out, but the balls will keep out a lot of the air and slow down evaporation. Otherwise design a floating lid of suitable material. Quote Link to comment Share on other sites More sharing options...
Charlotte Posted June 15, 2009 Share Posted June 15, 2009 Good thought Glenn. Quote Link to comment Share on other sites More sharing options...
ironantlerforge Posted June 15, 2009 Author Share Posted June 15, 2009 floating lid, good idea! Quote Link to comment Share on other sites More sharing options...
