saintjohnbarleycorn Posted May 13, 2009 Share Posted May 13, 2009 I am going to build a couple of forges with interchangeable burners. I have 3/4" burners. I know you need 250 to 300 cu" for to get to forge welding temp. So I can build a small one with one burner for that. How many cubic inches would you need if you just want forge heat? I would build a bigger one just for that. thanks for any advice on this. kevin Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 13, 2009 Share Posted May 13, 2009 A couple things. First you can just turn the pressure down if you don't heed welding heat. Second a well tuned 3/4" burner should bring up to 350cu/in to welding heat but that's at the upper limit. So, the short answer would be 350-400 cu/in volume and you will still get high orange low yellow but not likely to welding heat. Frosty Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted May 14, 2009 Author Share Posted May 14, 2009 thanks, I was looking to get a larger area for just forging, push the burners. I will go with a 700 cu", and probably a 250 cu" if I want to do welding billets. I guess the pictures just seem like they are bigger. Quote Link to comment Share on other sites More sharing options...
Frosty Posted May 14, 2009 Share Posted May 14, 2009 The inside of a forge is always smaller than it seems and the outside seems disproportionally large. 700 cu/in may be too much volume to get much into orange heat, even insulated. A door will make a big difference of course but that still seems awfully large. Then again it's easier to add another or a larger burner than it is to enlarge the forge itself. I always try to design so adjustments take the easy route. Frosty Quote Link to comment Share on other sites More sharing options...
