triw Posted May 7, 2009 Share Posted May 7, 2009 Here is a guillotine tool I made to start the angle on my blades. I cut the angle in the tool with an angle grinder and files. The back of the cut is 1/4 " and is approx 2" long. I do not taper the blade to an edge with this but just start the taper. William Quote Link to comment Share on other sites More sharing options...
Dodge Posted May 7, 2009 Share Posted May 7, 2009 Neat!! Does it tend to cause a curve to the blade? (easily corrected) but just curious :) Quote Link to comment Share on other sites More sharing options...
Steve Sells Posted May 7, 2009 Share Posted May 7, 2009 if this is how you get the bevel, how does manage the distal taper? Quote Link to comment Share on other sites More sharing options...
triw Posted May 7, 2009 Author Share Posted May 7, 2009 (edited) Neat!! Does it tend to cause a curve to the blade? (easily corrected) but just curious I was taught to bend the blade before I do this so as the blade curves it actually strighten its self out. If you can figure out what I mean.if this is how you get the bevel, how does manage the distal taper? I draw out the distal taper by hand. Edited May 7, 2009 by triw Quote Link to comment Share on other sites More sharing options...
Dave Budd Posted May 7, 2009 Share Posted May 7, 2009 I'm guessing that you only use this to tidy up the transition from ricasso to blade bevel? If you are using it to forge out the bevel all the way along the blade then I reckon you are going about it the hard way! I've thought about making such a thing for tidying up but I've not found anything that I'm happy with, especially as I don't work to patterns (ie the same width/thicknes/taper of blade). Any chance of a picture of it in action? :) Quote Link to comment Share on other sites More sharing options...
triw Posted May 7, 2009 Author Share Posted May 7, 2009 (edited) I must have missed that part, as I assumed you were setting bevels along the blade the way it read. But I am good at being Confused easily. makes sense to be a necking tool. I like it Edited May 7, 2009 by steve sells Quote Link to comment Share on other sites More sharing options...
