SGropp Posted April 4, 2009 Share Posted April 4, 2009 I just bought 3 tons of what was called "smithing coke" from Utah. I bought it with a group of smiths here in the PNW to get the price down to a reasonable point. I am not sure of the exact origin as I was not part of setting up the deal. Good quality coal seems to be no longer available in our region, since Harry's Leather stopped carrying Cumberland Elkorn a few years ago. The coke is very clean, all about the size of a walnut , with virtually no fines. The clinker is harder and glassier than from coal. I am having a hard time getting it to burn as really as hot as I was hoping for. I am using a standard rectangular Centaur/Buffalo firepot with a Dayton electric blower [not sure of the CFM] which has worked fine with all the tons of coal I've put through it. My question is ; do I need a bigger blower? deeper firepot ? deeper fire? modified technique ? I've been experimenting with different methods of burning this coke but so far my success or not has been sporadic. I only use the coal/coke forge for small work,welding,short heats or pieces that will not fit in the gasser. The gas forge is so much more efficient for longer heats and multiple pieces, but the coal/coke forge is an an essential tool in the arsenal. Anybody here have any advise based on real experience with using this type of fuel? :confused: Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted April 4, 2009 Share Posted April 4, 2009 well I am not expert on this, but the coke I bought, I didn't have any trouble at all. it should burn hotter with not more air than regular coal. At least it doesn't seem to need that much more, if I want a hot fire I have to crank more on regular coal also. Quote Link to comment Share on other sites More sharing options...
johnptc Posted April 4, 2009 Share Posted April 4, 2009 (edited) for me its always a little picky about getting it going however once lit after about 20 minutes on low blower it gets crazy hot.....as an experiment you might try breaking it into smaller pieces which will give you more surface area per pound and should burner faster and hence hotter although i have a large blower most of the time it runs on the slowest speed the control allows.........i do kick it up a bit for forge welding but probaly not more than 25% of full speed Edited April 4, 2009 by johnptc Quote Link to comment Share on other sites More sharing options...
saintjohnbarleycorn Posted April 5, 2009 Share Posted April 5, 2009 if you are having a hard time starting it, use some wood scraps, pieces of 2x4 spilt thin the good wood fire will get the coke going very quickly. kevin Quote Link to comment Share on other sites More sharing options...
SGropp Posted April 23, 2009 Author Share Posted April 23, 2009 I solved the problem by replacing my fire pot [ which was shot anyway ] with a heavier and much shallower fire pot made especially for burning coke. I also upgraded to a bigger blower. I got both of these from Centaur Forge. It bolted right into my existing tuyere which also originally came from Centaur. I cemented it in flush with the bed of the forge table with Mizzou 3000 castable refactory from Seattle Pottery. This was not a cheap fix but now I'm back in business with some serious heat and no smoke or stink. Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted April 23, 2009 Share Posted April 23, 2009 glad you figured it out .. i have been useing coke for years and prefer it to coal for a lot of reasons but its easy liteing propertys isnt one of them.. just remember that if you leave the forge put a piece of wood into the middle of the fire .. it will keep it going longer so you dont have to refire the forge ... otherwise every time you leave it for a few minutes it will go out.... are you a member of nwba? if so see you at the 30th anaversary in the fall! Quote Link to comment Share on other sites More sharing options...
