My forge is based on the article, "Building the Side Draft Forge" written by Mark Aspery. This is the basic design of my forge. I made several changes to the forge to make it capable of being broken down into components not weighing over 50#. The water cooled Tuyere follows the dimensions in the article however the Tuyere is connected to the separate water tank via upper and bottom hoses. The hot water rises up the Tuyeres top pipe to enter the top of the tank and the cool water flows out the bottom water tank hose into the bottom of the Tuyere to circulate the water in the Tuyere.
The front portion of the Tuyere protrudes 8" into the Hearth. To use less coal, fire bricks were placed on either side of the protruding Tuyere which left about the last 2" of the Tuyere exposed to the heat of the fire. Other fire bricks were used to fill the space in the 2' square 9" deep Hearth. Since the Tuyere is water cooled, there was zero evidence of the fire heating or burning the exposed end of the Tuyere.
??Mikeyn, is your Tuyere water cooled or is it a bare pipe extending thru a bed of insulating clay?
I failed to determine what was blocking the air pipe, I just pushed a rod thru the pipe to clear it. The blockage was solid black when viewed thru the opened rear of the air tube. When the blockage was pushed out with no difficulty, I assumed it was ashes and possibly some fill lime from the Duck's Nest.
Every time steel bar stock was placed in the fire zone, the coal was pushed out the other side, requiring the coal to be raked back into the fire zone. Since the bottom of the Tuyere is buried in the fill lime, the air tube hole is only a little over an inch above the fill lime. After the fire was established, the coal used was Anthracite "Nut Coal" purchased from Tractor Supply. The Nut coal is in walnut size chunks with very little fines or dust. However, the Nut coal burns with a considerable flame (which eats any smoke) and creates a bright yellow/white heat when the full air blast is used.
After 4 hours burn time, the fire was pulled to extinguish it. There were two small 2" dia. clinkers pulled out of the bottom of the Duck's Nest plus ashes, coke, and unburnt coal all mixed with a little fill lime.
I wrote to Mark Aspery and received a response suggesting that raking the coal back into the fire could also cause fill lime and ashes to be raked into the air tube and cause its blockage.
I have a theory: Since the anthracite coal is extremely hot, is possible that some of the coal and fill lime could be pushed into the air pipe during raking (as Mark suggested), the coal could quickly burn out and then with the cooling air supply hitting it, cool to a mass?
When I get the forge back together, the Tuyere will be raised 4-5 inches above the bottom of the Hearth. Sand will be used and the fill lime removed. The Tuyere air pipe will be changed to add a "T" section with the back side of the "T" giving access to clean out the air pipe. Then, I will carefully inspect any air blockage to determine what it is. Also, is the blockage inside the air pipe or is it clustered ash outside the pipes opening.
PS: I live in Scotch Grove, Iowa which is between Cedar Rapids and Dubuque. So if any of the blacksmiths with a Side Blast Forge who lives within a 100 mile radiusI, I could possibly schedule a visit to review their Smithy to see how they have solved this and any other problem peculiar to the Side Draft Forge design.
