Flux for nickel
I have some pure nickel that I was wanting to melt and cast into an ingot. They are the size and shape of a charcoal briquette. It looks like they are pressed (sintered) together and just crumble when I tried to forge them. What, if any, do I use for a flux?
Water fountain
Spray on cold galv....available at Home Depot. 96% as effective as hot dip galvanizing
blower for ribbon forge
I am having trouble finding an electric forge blower for a ribbon forge. Grant Sarver (RIP) was selling them (I believe that there were two sizes) but he's not around to help. I have Googled, and gone to the blacksmith supply websites (Blacksmith Depot, Peih tools, Centaur forge, etc). I don't want to buy blowers to experiment with. My forge dims are: 10" high x 12" wide x 18" long. Any help would be appreciated. Thanks
how to get heat patina on the handle ?
I have been temper-coloring for years.....but, I have not been able to coat it without wrecking the color :( The colors darken and turn blah brown :angry: I have tried spray can gloss clear enamel and lacquer. What is the secret/product/technique??? Thank you.....
- Lily candleholder
Ohio Knife Company blades
I recently obtained some blanks of steel of various sizes. Etched on the surface is: The Ohio Knife Company. Portland, Oregon. 83-2454-03. #4 H. S. S. knives. I don't usually use the stock removal method for making my knives. I am wondering how well this steel forges, and what heat treatment would be best. Any info would be appreciated. I have attached a picture of my latest knife made from 5160 alloy steel.
What type of burner for first gas forge?
For the best And most information go to the ABANA website. Scroll down to the link for Ron Reil. Go there and study all the info. He covers burner design, different styles of burners, sizes, computing burner size vs forge volume, etc. Read as much as you need to, in order to make your decision. Placement of burner in forge is much discussed on this forum. Do some searching.
Happy Birthday USMC
It means more to me now (40+ years later) than it did then (when I got called a baby killer upon returning from VN). It has been a relief to find that the public realizes that we didn't make the policy, just answered the call.I sometime wonder how many would have answered the call in 1776?
Young Frankenstien The Musical
Sounds interesting, on a few levels. Can you tell me where I can get a copy? Thanks.
Hammers and stakes
As far as books are concerned you HAVE TO GET " Silversmithing" by R Finegold & W Seitz. I found my copy at Powell's in Portland. It covers tools, metal as well as wood, hammers, stakes, etc. as well as techniques, design, layout, math (so you don't end up with wasted material), terminology, etc. Agreat book for anyone who wants to know how to shape sheet metal.
Reflections on wrought iron
I got a piece gratis from pureiron when I attended the ABANA conference in Seattle. What is the difference in it and wrought? Also look in back issues of Anvil's ring (in the classifieds). Someone had come across tons of wrought iron fence posts. I believe they were 1 1/4" x 5 or 6 foot long.
3" spun ball
I have done some tig welding on copper. It works great. Holds together better than aluminum, but at 'some' temperature it slumps. Also the filler rod gets hot. I also use 1.5 magnification inserts in my helmet. I need to use an 'old time' helmet on small stuff, as the coating on the electronic helmet lens distorts the image. After welding (or soldering ) the ball will be dead soft.
Banksia, Brass and spring steel
Godd work on the knife and the photography. Reflections in the blade make it look exotic. Can you tell me more about the wood. I have never heard of it.
Metal spinning
Yes , I am testing the waters.....I don't know where I can get this done, so I am asking if someone knows. Jusat like anyone would do when they want to have something done (welding, machining, cabinetry, plumbing). If I missed my 'guess' on the cost, well, I didn't realize what a 2ft piece of copper sheet would cost. Seems to me that an hour would make the get the job done. As far as the form........I can adjust the dimensions to a form that is already made. If the cost is too high....I'll do it myself. As far as the other comments on this matter...... I do metal work for a living (weld, fab, forge, sheet metal, machining, knives, jewelry, etc), so I know what it takes to make something. Sometimes I go 'outside' to someone with the expertise, or special equiptment. An example of this would be buying a hinge, rather than making one. HHHMMMM make a hinge, or buy a hinge.....HHHHMMMMMM????? I started this post to find someone to spin a bowl. It gets really annoying, to have inquiries turned into a chat room for know-it-all's, who have no idea of my situation, abilities or talents.
Metal spinning
I live near Portland, Oregon. I need a dish/bowl spun in copper. Size: about 9" deep and 16" in diameter with a 4" flat on the bottom. Thickness about .080" to .120". I would raise it myself except for the size. Cost should be less than $100. Any help would be appreciated. Thanks.
