516 -
Posts posted by saintjohnbarleycorn
Is balance just the matter of feel in your hand, or is there somewhat more scientific approach to it?
honorable attitude!
i made up a batch of sperquench, I will give it a go on them.
thanks thomas. -
Thanks, as usual a lot to learn about things. I would guess that the crystal structure of the steel would have something to do with it. There is also "Bell brass" they use in banjo's so there must be different types of brass. I may do some experimenting on this one, but as time is an issue here, (birthday present) I have some 1/2" square that I will use. The diameter of the hay rake is 3/8" or less. Don't have a lot of spring material, but I am curious about this. thanks again.
is it better to make one of these with higher carbon, as in it i will ring nicer? I have the choice of mild and the hay rake teeth (.95) or so . thanks.
sweet! glad you like it!
thanks for the info I will keep that in mind along with the other suggestions.
If I know what you are talking about, there is no gasket, the oil stays on the bottom and is carried up with the gears as you turn it. Mine seeps a little here and there I think the last time that I put oil in it I used 30 weight or 90 weight I can't remember and it didnt' seem to make much difference. That was a good find you got. good luck.
I guess for hardening, I should go with straw, because of the low carbon content?
mine would be outcome at this point!
having been on many other sites.. I would say this is one of the best. very polite and civilized in every way. thanks Glenn for a great job.
yes just saw it yesterday on one of these threads somewhere. It looks like a great site, I have registered and will be on there soon. thank.s
thanks A man
Well I will sit on it for a while and see what comes up. A used one sounds like a good way to go, but something not over 1000 pounds I would guess, just for the sake of moving it from here to there. thanks.
Thanks for the input, I have a bucket of vermiculite but have not put it to much use yet. The warmed sand sounds good also. The high carbon spikes I think were said to be .30 so that is not that much anyway I would not think. I was confused, because of the .95 hay rake teeth. The things I saw on them never mentions a double annealing.
I read the bp on it, anneal twice, bring to heat and leave in forge overnight. Well that the way I remember it anyway. I was wondering why they need more special attention than say 95 point straight carbon steel?
2. I was also thinkning that at 19 degrees out the forge kind of cools pretty quickly overnight, and might it be better to put it in the woodstovefireplace over night as it would cool very slowly over a 8 or ten hour period.
thanks. -
Thanks, thats a little bigger than I thought i would want to move around, but I am going to check it out anyway!
stretch any chance of a picture of you grinder? thanks.
What type of lathe can you get for under $1,000. I have never used one, except a wood lathe. I would like to use if for turning small parts, doing threads, and for sizing shafts for making other tools and the like. I don't really have a good idea of what size you need for what job. I don't know of any used places around here, maybe in philly, and I would like one that doesn't need a lot of work that I don't know how to do to fix it. It would be an adjunct to the metal working I am doing now. thanks for any input.
If you didn't have a lathe would you just buy the wheels? I see they have a 6" rubber coated for the main drive wheel. Also would you direct drive or use a belt? thanks
Ok so they are saying that we are going to get $600 back. whether that is a good idea or not is not the question. But If they do what tool would you buy for your blacksmit shop, that you have wanted to but have not bit the bullet yet? A bandsaw, chop saw, oxy/acet ...... What are your ideas.
very interesting, thanks for the information, sounds like a good place to live!
There is also the Stainless Steel variety for the outside, at least at the elbows for corrosion if it turns out to go outside again.
The used quickly I am not sure about a lump of it hangs around for a while, but overnight in a freezer it will dissapear, its about -100 F so you need to be a bit careful handling it. Also don't put it in a sealed container it will expand and blow up.
dinner triangle
Posted
Well I made one and it doesn't sound so good. I made it about 20" on the three sides. I am thinking that the length will also affect the sound. A certain length will probably resonate more with 1/2" square. Like 18" will will resonate more than 20" or visa versa. What are the dimensions of the one that were made with 1/2" square? thanks.
