Hi eggwelder thank you for that complement .
yes i prefere to do everything myself thanks,Heres another i just finished from coil.
copper and raw hide wraps , beading and a hawk drop .
Chris
One wrap and weld others slit and drift.raw hide wraps ,brass studs, horse hair , Deer,and beading
slit and drift from 1 inch coil .bleeding heart cut outs.
Hi Scrap rat thats a pretty wide open question there .
i think most of us know you can splt rock apart with wooden wedges so
you main object is to get that fire weld real good .,
i normaly weld the eye a few times to make sure you dont have a week spot
up around your eye .if you do you will find it will open when you drive your tapered tear drop haft in .
Harden like you would a normal axe
cutting edge leave main body realitively soft .temper back to what your after .the life of any tool is in the hardening and tempering
thanks Scrap rat
Chris
Hi Dan C i do use both process mate heres a couple of pix of both ways.
all i did with the rasp was heat up a bit to get rust and stuff.off wire brush then fire weld and put another piece of file in for the cutting edge ,
The other is slit and drift from 1 inch coil spring
Chris
Hi Whirly thanks mate , looks a bit snakey looking i think after i made the sheath i thought i should have use snake skin instead
oh well next time ,appreciate and thanks for likeing my work .
Chris
Hi found some old rasps laying around the shed so i decided to forge out a couple
of hawks , Used spotted gum for hafts and wraped with raw hide , not much cleaning up on these
had enough to make a rasp kife as well hope you like .
Chris
Hi mond
Thank you for your nice comment , havent done that been buzy making some from so
old rasps i found laying around the shed ,i will have to get around to it after i finnish these couple off
thanks.
Chris
