Hi Fe-Wood, it'd be interesting to discuss power systems. This happened along with some other power upgrades, should be 24v by now, but so it goes.
I' been working with hydraulics for a few years, on my tractor, and being around logging equipment. If you think about how a typical shovel operator uses that machine, it's amazing that a high pressure system holds together as well as they do. I figured if I use the same type steel lines, and fittings, should be pretty safe in a static enviroment, and except for day one, the only fluid on the floor has been changing fittings.
Day one, however, got a bit exciting when I fired it up, I'd plumbed backwards, and got a startle when the filter blew off the reservoir, spraying the wall with oil.
Got that straightened out, but even then I keep the pressure down around 1500. I did all the return lines in 3/4" black iron pipe.
I love the flow control valves, I can turn the lathe at about 2 rpm, with enough torque to really break things. I'm thinking with the back gear enguaged, I could do some interesting twisting, with the 8' bed available.
I'm on a slow going learning curve with the lathe, other than turning parts, I've only set up to cut threads for some backing plates, and havnt gotten into power feed on it at all. If ya want a pic of anything there, just point.
Over at the press is a good place for the "master" valve bank, where I also located the 12v switch that activates the 12v clutch on the hyd. pump, start and stop hyd. pressure right there. I probably run the kubota around 1800-2000, things get moving fast enough for me at that, and to be honest, I havn't been gutsy enough to get anything moving that fast in the lathe.
I noticed some folks in the press section have electric driven pumps going on, know of anyone else doing something on a small scale like this?
Even tho I started long ago (to me anyway) this is really just my 3d winter in the shop, with amenities like walls, and doors.
