Admanfrd Posted February 2, 2014 Share Posted February 2, 2014 Today, i went and saw an awesome old man with 8 ANVILS! although they were nice, they were out of our price range. one we found was in immaculate condition and we think we can talk him into $200.00 for it. regardless, i think it may have a crack in it between the body and the waist under the weight denomination but i cant tell. here's a couple of pictures Quote Link to comment Share on other sites More sharing options...
Fatfudd Posted February 2, 2014 Share Posted February 2, 2014 That is a typical arm and hammer face plate. I have several and they all look the same as that one. A&H anvils were noted for being excellent utilitarian anvils but were not well finished to keep the costs down. If the anvil has a good clear bell ring with no buzzing or dead sounding spots anywhere you tap it, along with good rebound, then it is fine. If you can get it for $200 you will be getting a killer deal. They are pretty rare and usually expensive when you do find them. Here are two of mine and the larger one has a very clear line between the face plate and the body. Quote Link to comment Share on other sites More sharing options...
clinton Posted February 2, 2014 Share Posted February 2, 2014 You are seeing the forge weld at the waist I would grab that anvil up if possible. It looks like 145? You would be less than $1.50/ pound Quote Link to comment Share on other sites More sharing options...
Fatfudd Posted February 2, 2014 Share Posted February 2, 2014 Clinton is correct, I mis-read your post. The forge weld at the waist is also not an issue. Again A&H didn't worry about looks only the quality of the product. Hopefully you can garb that anvil, I would! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 2, 2014 Share Posted February 2, 2014 As mentioned traditionally made anvils have a weld in the waist area and A&H's tend not to have a dressed appearance. These anvil are considered top tier in quality for usability. Check it for ring---it should and if it rings clear there are no hidden cracks. The most modern of them had the waist arc welded instead of forge welded! Quote Link to comment Share on other sites More sharing options...
Admanfrd Posted February 2, 2014 Author Share Posted February 2, 2014 Thanks guys! i was really worried! ill be grabbing this up Quote Link to comment Share on other sites More sharing options...
