leroyk Posted March 7, 2009 Share Posted March 7, 2009 I am making drawing dies for a press to draw out billets to make damascus steel for knife blades. what knid of radius do i need to do this? I am thinking about using a 2 in shaft split for each half of the set of dies. Any help with this w ould be appericated. Leroyk Quote Link to comment Share on other sites More sharing options...
dablacksmith Posted March 8, 2009 Share Posted March 8, 2009 that will work but... how many ton press? how fast does the ram move? what type of damascus pattern are you going to make? these are inportant questions because by useing drawing dies it will change the pattern... if your going to make mosaeic damascus you might want to go with flat dies so as to not distort the pattern....just my 2 cents worth... you might also want to put this question in the knife section.. Quote Link to comment Share on other sites More sharing options...
leroyk Posted March 12, 2009 Author Share Posted March 12, 2009 basically i am just into random pattern for now. the press is about 20 ton. movement is on the slow side. thanks for info lee Quote Link to comment Share on other sites More sharing options...
