DavidBrandow Posted February 25, 2009 Share Posted February 25, 2009 Up until now, I've just been using boiled linseed oil, but I wanted to get some beeswax and start using that as well. What I don't know, however, is how much beeswax I'm likely to use. For an hobbyist, how much am I likely to go through, ballpark? Quote Link to comment Share on other sites More sharing options...
P. Bedard Posted February 25, 2009 Share Posted February 25, 2009 I guess it all depends on how much stuff you produce. I usually buy a candle or two for small pieces and they last me quite a while. Remember, you're not soaking the hot iron in the stuff, just letting it soak into the steel while the piece is too hot to touch. Quote Link to comment Share on other sites More sharing options...
Frosty Posted February 25, 2009 Share Posted February 25, 2009 A little goes a long ways, 1 lb. should last you a year or better unless you're doing a railing or something big or doing a lot of production. Just hold the piece up and touch the wax to it, if it smokes much let it cool till the wax melts with just a little smoke. It'll be very fluid and coat well. Let it cool till the wax begins to set, the sheen will change, and wipe it off with a cotton rag. Always use the same rag. After a while you'll be able to just wipe small pieces down with the rag to finish them. (hot of course) Frosty Quote Link to comment Share on other sites More sharing options...
