January 30, 200917 yr W2 is supposed to make a good knife. But at the local steel supplier they sell W1. Is W1 simillar to W2? Would it make a good knife steel? Thanks, Chris
January 30, 200917 yr Typical Analysis: Carbon Chromium Manganese Molybdenum Nickel Silicon Tungsten Vanadium W1 0.70-1.50% 0.15% 0.10-0.40% 0.10% 0.20% 0.10-0.40% 0.50% 0.10% W-2 0.85-1.50% 0.15% 0.10-0.40% 0.10% 0.20% 0.10-0.40% 0.15% 0.15-0.35% They are about the same and either will make a good blade.
February 2, 200917 yr The higher vanadium in W2 helps to inhibit grain growth and makes it easier to use high heats for clay backing/hamon work and pattern welding without AS MUCH fear of overheating the steel for long perods of time. Of course, some simple post-forging techniques, and grain growth is a mute point. I've used lots of both and enjoy them immensely.
