Adirondacker Posted January 27, 2009 Posted January 27, 2009 I have been working in the shop during this bitter cold we are having. The sawmill doesn't run well below twenty to many hyd lines. Anyways I have been wanting to get started beating some iron so I made a small forge out of some 6" well casing, copper pipe, pvc and a hair dryer. Got it together yesterday but need some fire brick for the bottom, for now I will use some charcoal left over from a party last summer and try this out. I have a project in mind, We make signs out of heavy pine slabs with lettering and numbers handsawn out of basswood, I have an order for a house number on a pine slab, this will hang from a angle iron bracket. With just three numbers the pine slab looks a little bare, so I took some pictures of Crane Mountain from different angles till I found one that suited me, down loaded this and printed out. then I cut the profile of the mountain out and transfered this to a 1/2 piece of wood, then cut this out on the bandsaw, and sanded it down. My hope is to bend 1/2" sq stock into profile of Crane Mountain and mount this to pine slab, think will add a nice touch, can see this in my minds eye, now have to make it real. Just wanted you to know that I got going in trying to learn a new skill. Adirondacker Quote
welder19 Posted January 27, 2009 Posted January 27, 2009 Sounds interesting, be sure to share some pix. welder19 Quote
BeaverDamForge Posted January 27, 2009 Posted January 27, 2009 Sounds interesting, be sure to share some pix. welder19Seconded! Good Luck! Quote
