Crawler tractor treads, what's in 'em?
The steel that is used in crawler tractor track pads must be pretty good stuff, the beating they take. Wonder what it is. Tough and quite hard, What do you suppose could be made out of cat treads? I have some of the stuff, maybe eighty feet of track.
Has anybody out there used this kind of steel and what for. And what is it? Straight carbon or any alloying?
Warren
The pins are normally a case hardening steel such as 4317/17cnm06/en36. The tracks themselves are as I recall normally cast. Only guessing but something like Nihard would be likely. En36 is fantastic for dies, just make your die as needed, then take it up to approx 800 degrees C and throw it into water. No need to temper it. In use just make sure that you keep cooling it between heats. We have forging dies that we made over 7 years ago from En36 heat treated as I described, that have made 100s of jobs each without any deformation or wear.
Cheers
Phil
Thank you Phil,
The pads are apparently hot rolled with pad and grouser as it comes off the rolls and then sheared to length and then holes punched.
Warren
more than likely, a high manganese steel, anti crushing and high abrasion resistance.
I don't know what they are but in NC or SC there is a company that rebuilds them. Builds up worn cleats or whatever there called. A google search may help.
