Made some tools for my flypress
All tooling has a 1 inch spiggot, a standard size for larger flypresses.
So far I've made the bottom bolster, a set of fullering dies, a v bender and a punch which is fitted to a 1" to 19mm adaptor. I made the adaptor because I've got about 20kg of 19mm H13.
Here I'm turning the spiggot for the top V block, it is an interference fit. The spiggot was left in the freezer for a few hours to shrink a wee bit and the block was heated to enlarge the hole. They're not coming apart again, ever.
Here's some 19mm bar that I bent, I also flared one end into an angle shape. This may be useful for making gouges etc. I also punched a hole into a piece of 6mm steel.
Here's a pair of dies with a slight convex face, used for setting the weld when making pattern welded steel. Hopefully the convex shape will push the flux out of the billet as it gets pressed. This should reduce the amout of crap that gets trapped in the billet.
Here I'm putting a 11" diameter convex radius on the end of a bar of H13 (2" square)
Hopefully you can see the finished radius in this photo.
here's the finished dies:
Looks good. It's certainly helpful to have a few machine tools in a blacksmith shop, eh?
You've piqued my interest. I like what I see, but I'd really like to see a couple of photos of the entire flypress.
Hoot! That's a flypress! So, the weights are simply held in place with gravity, and you haven't yet installed them in the first photo? Are you holding a part to a smaller press in the second photo? How are flypresses rated and where is your big press on that rating scale?
My son likes your bicycle. Seems there is a resurgence of the classic road bikes (the retro bike), and apparently yours has possibilities. ;)
Hoot! That's a flypress! So, the weights are simply held in place with gravity yes, and you haven't yet installed them in the first photo? Are you holding a part to a smaller press in the second photo? A fly arm from a size 6 press How are flypresses rated and where is your big press on that rating scale?
It's a size 10
It's my old road bike circa 1982. It's a hand built frame (Reynolds 531 tubing) with good quality components. e.g. Shimano 600 series train, handbuilt wheels, Brooks seat...
