Killerchef69 Posted February 18 Share Posted February 18 Looking for some guidance/ ideas to turn this screw press (originally a leather embossing press). The shape and strength are there, but the main issues I'm seeing are flat pitch lead screw (about 3 turns per inch), needs a ram block and guide, work holding/ tooling retention It currently has a flat platen that is supported by the big C frame, so I'm thinking of boring a hole for holding dies(not all the way through) and adding a plate with t-slots Adding a plate in the back of the throat to support ram block guides. The biggest constraint I'm seeing is a fast lead screw/ nut, so Looking for ideas for that. I currently have a pretty fast lead screw (1" 3 start, with just over an inch of travel per turn), but the nut that is on it is only threaded for a couple of inches and appears to be cast iron, soooo another dilemma. I also feel that the fly arm that is on the press would be too much for a 1" shaft (it's probably 75#). Working on a stout base with 2"x4" box tube (sort of perimeter frame to accommodate the C frame) with flared legs of 1/2" thick 3" angle iron. Any suggestions on approaching these challenges would be greatly appreciated! Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 19 Share Posted February 19 Welcome from the Ozark Mountains. If you put your general location in your profile, you may be surprised how many members may be near you to lend a helping hand. I can't really help as fly & screw presses are not in my area of expertise. I'm reasonably sure some of our current members have some experience with them. I can't control the wind, all I can do is adjust my sail’s. Semper Paratus Quote Link to comment Share on other sites More sharing options...
Killerchef69 Posted February 19 Author Share Posted February 19 Thanks, I'm in the northern California foothills (gold country we like to say! ) Quote Link to comment Share on other sites More sharing options...
