sunironworks Posted January 10, 2006 Share Posted January 10, 2006 Hello, Does anyone have any experience with plastic steel in a sliding application? There's this power hammer i am considering, big, old, slow, low-pressure air cylinders, that has a rot hole in the cylinder wall about an inch across, down low in the stroke. It was fixed with plastic steel, probably the titanium stuff. Any idea if it's likely to hold or would you expect it to just turn to goo or shave away? THanks JRF Quote Link to comment Share on other sites More sharing options...
irnsrgn Posted January 10, 2006 Share Posted January 10, 2006 anay kind of patch is a waste of time and cobble fix, the cylinder tube needs to be replaced. If its worth fixing, fix it right the first time. Quote Link to comment Share on other sites More sharing options...
