September 18, 200817 yr I just got a good deal on an old forge. The problem is the tuyere is very rusted and need to be replaced and the cover that lets the clinkers drop out the bottom is rusted solid. I wanted to try and remove as much of the rust as I could before I considered drilling out the bolts. I did a search and it mentioned Blueprint 0448 was on rust removal, Is there any chance someone has it? Or I'll take any suggestions on how to fix it. Thank you, Mark Gilg
September 18, 200817 yr IForgeIron has it. I manually pull the material and get you the information. Check your pm.
September 18, 200817 yr Google for electrolysis rust removal. Here is one link Rust removal by electrolysis I have some Little Giant parts going in a tank in my shop at the moment. This process will remove caked on crud, rust and even old paint.
