trattoclip Posted September 4, 2008 Share Posted September 4, 2008 GOOD MORNING GUYS ! Is there a good formula to etch a damascus pattern ? I use this material - c-40 c-70 - c90 a solution of 70% Ferric Chloride 30% distilled water wash with water and 10% of sodium bicarbonate. polish with 600 grit or up take this formula to AES custom knife Many thanks for your help Quote Link to comment Share on other sites More sharing options...
Ed Caffrey Posted September 4, 2008 Share Posted September 4, 2008 Most of use use Ferric chloride, but we mix it 1 part ferric to 3 parts distilled water. Basically the reverse of what you mentioned. As a general rule with damascus, the slower the etchant, the better the etched blade will come out. If the etch is too aggressive, you will often get what we call a "muddy" pattern, where things look smeared together instead of a crisp definition between the materials. I'm not familiar with the steel types you listed (European?) Another hint for etching is CLEAN. The blade must be 100% clean before etching. I use latex gloves, clean the blade with acetone, followed by window cleaner. I use TSP (trisodium phosphate) after the etch to neutralize, and scrub the blade with #0000 steel wool and soapy water. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted September 4, 2008 Share Posted September 4, 2008 Sort of depends on what you want out of an etch. For my bandsawblade and pallet strapping billets I like hot vinegar and salt as it show the pattern *BRIGHT* rather than the dull grey of ferric chloride. OTOH it doesn make any topography Very strong tea makes for a different etch with purple black highlights on some alloys. (but no topography) Many folks like topography but it gets in the way of a using knife in my opinion. Quote Link to comment Share on other sites More sharing options...
trattoclip Posted September 5, 2008 Author Share Posted September 5, 2008 many thanks for your help guys ! Quote Link to comment Share on other sites More sharing options...
