August 27, 200817 yr I just purchased my first anvil and would like to know if anyone can help me pinpoint when it was made and any good or bad points about it.It is a trenton anvil stamped 119 usa on one side,and on the front left side of the foot a T letter and then the right side of the front foot A2639,it's not in bad shape,just a few small chips along each side of the face,I read that the old smiths used to round off the sides of the face 1/2"to 3/8' to prevent chips accuring along the face,is this a good recommendation,let me know,any info will be helpful.
August 27, 200817 yr Nice score! Can't help you much with specific info though. I was always told that grinding some different radiuses (SP???) in your anvil face gives you consistent curves to work on depending what you're making (times when you need a 1/2" radius in a piece of work). But you still want to keep good square edges as well. Anyone else been taught this? aeneas
August 27, 200817 yr I tend to leave the edges of my anvil alone and make mandrils for curve and angle work. That way they can be specific to the work and your anvil is preserved.
August 27, 200817 yr Nice score! Can't help you much with specific info though. I was always told that grinding some different radiuses (SP???) in your anvil face gives you consistent curves to work on depending what you're making (times when you need a 1/2" radius in a piece of work). But you still want to keep good square edges as well. Anyone else been taught this? aeneas ya same I have to edges about 4 inches long that have a radius but left some sharp edges for cleaning up corners etc. Just remeber the obvious, easier to take the material away then put it back!!
August 27, 200817 yr We can find out the date from the serial number in Anvils in America, (don't have a copy at work), Trenton is an excellent quality American made anvil that at least for their later years made anvils in Columbus Ohio. The exact construction depends on time as they switched to cast steel bases at one point welded to the tops IIRC. I generally ignore the chips on the side of my anvils and just leave them alone and make a hardy tool if I need a certain radius edge---you can make one with 4 different radii and just place it in the hardy with the one you need in the orientation you need.
August 27, 200817 yr Author Thanks,good idea,I got a response from a gentleman in michigan and he said according to the book Anvils in America my anvil was forged in Columbus,Ohio in 1899,it has the hourglass depression under the base,my next question is,is it wrought iron,cast iron,cast steel,or a mix of any of these,any info will be greatly appreciated,thanks
August 27, 200817 yr I think that would have a cast steel base with a wrought iron top, and a steel face (I could be wrong though). I have a similar designed 102 pound Trenton.
August 28, 200817 yr In 1899 I thought it still had an all wrought iron body with the tool steel top. Anvils in America will tell when they switched to the other formats as I am not at all sure of this.
August 28, 200817 yr That could be. I was under the impression that the hourglass depression was cast in, not forged into wrought iron. But like I said, I could be wrong as I am far from an expert.
August 28, 200817 yr I just got a 150 pound Trenton about a week and half ago. Mine says right on the side "Wrought Iron". I didn't find a date. Maybe I should look it over a little better.
August 29, 200817 yr Trentons don't have a date on them. Post serial no someone with AIA can give you a date. Ken
