angiolino Posted April 4, 2021 Share Posted April 4, 2021 help construction design realization gin pole: hello we will have to build a gin pole hoist to be installed as a foruna crane on the flatbed of a truck, to transform it when needed into a makeshift crane to be used on the farm, some ideas some constructive suggestions, we will have to make the support supports to hinge the arms to the platform and the tie rods to support the same to the body any ideas? http://img.iweku.com/upload/f/c0/fc021be8352c50cc07021d6ed452bac8_thumb.jpg http://img.iweku.com/upload/e/a9/ea988e6cb1cb3fefbf966a359b64593a_thumb.jpghttp://img.iweku.com/upload/3/5c/35c28a4fa27f80c20a1906c35312ccaa_thumb.jpg Autocarro Medio Fiat 80 CARATTERISTICHE E PRESTAZIONI PRINCIPALI Cilindrata: 5499cm3 N. cilindri: 6 Potenza: kW:117,8; CV: 160 a 3200 giri/min Coppia: Nm: 392; kgm: 40 a 2000 giri/min N. Marce: 5 Riduttore: si Trazione: integrale Velocità max: 93 km/h Carburante : gasolio Autonomia: 500 km Capacità serbatoio: 145 litri Dimensioni: Lunghezza: 6413mm Larghezza: 2295 mm Altezza: 3085mm Peso: 5930 kg Portata: 4000 kg Peso rimorchiabile: 6400 kg N. batterie: 2 Tensione: 24 V N. posti: cabina: 2; cassone: 18 Dimensione cassone: Lunghezza: 4255mm Larghezza: 2200mm Altezza: 500mm Quote Link to comment Share on other sites More sharing options...
