cds333 Posted February 10, 2021 Share Posted February 10, 2021 I am trying to decide between two possible shells for a furnace build. One would be a standard grill-size propane tank and the other would be a slightly smaller green freon tank. I would be using a #3 or #4 crucible which would fit better in the smaller tank, however I think I would prefer the heavier gauge metal of the propane tank as it is easier to weld handles and hinges to. If I were to go with the larger propane tank, how much efficiency would be lost by having a larger amount of air space between the kaowool and the crucible? What are the implications of having such a design? i.e. a small crucible relative to the diameter of the furnace? Thank you! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 11, 2021 Share Posted February 11, 2021 Is this a propane, natural gas, charcoal or coke fueled furnace? Quote Link to comment Share on other sites More sharing options...
cds333 Posted February 11, 2021 Author Share Posted February 11, 2021 Propane with a single 3/4" venturi burner Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 11, 2021 Share Posted February 11, 2021 Have you thought of adding another layer of insulation to cut down the interior size? You do want enough of a gap to get a good swirl around the crucible to transfer heat. Quote Link to comment Share on other sites More sharing options...
cds333 Posted February 12, 2021 Author Share Posted February 12, 2021 I had considered that but that would double the cost of the most expensive consumable. Would doubling the kaowool actually give a significant increase in heat retention efficiency such that the costs would balance out? Also is there a known preferred gap between insulation and crucible? Thank you! Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted February 12, 2021 Share Posted February 12, 2021 Consumable yes; but as you add it in layers you just replace the inmost layer as needed. There is probably a documented good gap; but I don't know it. Anything in the backyardmetalcasting.com archives? (I heat my crucibles with coke where you want the fuel in contact with the crucible.) Quote Link to comment Share on other sites More sharing options...
