angiolino Posted February 5, 2021 Share Posted February 5, 2021 hello, sorry if I disturb, I should make a boom pole for a small tracked power shovel it is a fiat allis fl 5 weighing 8 tons, 90 horsepower engine 3.97 meters height of the bucket discharge pin bucket capacity 1 cubic meter, keep in mind that a meter of gravel weighs about 1.5, 1, 8 tons as weight. how should I conceive it, what material I use, how to attach it to the bucket, how much can protrude from the bucket to prevent the machine from overturning, for the stability of the center of gravity of the mechanical shovel, how to reinforce the bucket the fiat fl5 is the same in size, weight and power as the caterpillar 931. thanks sorry if I disturb you. the boom will serve when it is necessary to load and lift loads as needed. Quote Link to comment Share on other sites More sharing options...
rockstar.esq Posted February 16, 2021 Share Posted February 16, 2021 Angiolino, I'm not sure this is a good idea as it may make a good tool, into a dangerous tool. Quote Link to comment Share on other sites More sharing options...
angiolino Posted February 18, 2021 Author Share Posted February 18, 2021 it does not have to lift tons when you need 300 500 kg maximum at low heights the convenience of a small lifting crane a small courtesy forklift. not big and heavy weight lifting. http://gardentractortalk.com/forums/topic/58611-front-end-loader-jib-boom/ https://www.qualityweldingservice.com/qm22/index.php/extenda-boom.html https://www.qualityweldingservice.com/qm22/pub/media/catalog/product/cache/c9e0b0ef589f3508e5ba515cde53c5ff/b/o/boom-extenda-20ft-horiz-reach_1.jpg https://encrypted-tbn0.gstatic.com/images?q=tbn:ANd9GcQWNzqWSlNNLoE2OkzfqIzgNCpJC4nVGhrMJw&usqp=CAU Quote Link to comment Share on other sites More sharing options...
