December 18, 20196 yr I have a primarily vegetable oil furnace with a diesel start. Has anybody added a spin vane with good results? I want to add a helical Air turbulence chamber to my burn tube.
December 19, 20196 yr Author Thank you Glen for, The personal message, that you moved this to a more appropriate forum. Maybe very few here spin their air?
December 19, 20196 yr Very few folks here use oil burners; they seem to be a bit more common with foundry folks as I recall. (Anything over at alloyavenue.com on them?) You will add some depth to the knowledge base here!
December 19, 20196 yr I'm interested in what you find out. Producing a viable oil burning forge has been quite a challenge.
December 19, 20196 yr I've seen several in industrial settings, including one that is now a museum in Lauf ADP Germany that was still in use for demonstrations when I visited 20 something years ago; but they tend towards the large size compared to most home forges.
December 19, 20196 yr Author I have a small foundry that has a 4 1/2 exhaust port. The magic will start inside the brick bace. The flames will be entering the bottom of the forge. It will be designed just like a big oil furnace. I want to try to get my combustion air up first.
