DanJohnson Posted November 17, 2019 Posted November 17, 2019 Any idea of the approximate speed the blower below was meant to run at? It has a belt/pulley and it isn't clear to me if it was meant to run off a motor or hand crank system. Thanks in advance. Dan Quote
Jim Coke Posted November 17, 2019 Posted November 17, 2019 Greetings Dan, What you have is a blower from a lever pumper style forge. The drive pulley that is attached to a ratchet mechanism is about 18 inches in diameter. It is designed to be an on demand style ( when you need air to the forge you just pump. ) Look up early Champion forges with a lever . Forge on and make beautiful things Jim Quote
