WoodFireMetal Posted August 24, 2019 Share Posted August 24, 2019 I recently acquired a neat stump anvil, as well as a tiny one whose horn would probably fit a jewelry ring. The larger one was welded to a thick pipe and tractor hub and I’ve just sliced through the weld and discovered a lot less stake than I expected to. I wanted to strip the paint and drive it into a stump to be able to take it to outreach demo programs for the museums I belong to. Are the stake ends always this short? Or did I just screw myself over by breaking it off its existing base? It’s only 4” long, though very thick. Also...is a sanding disc on an angle grinder ok to strip the paint? I tried a small wire wheel on my drill and it wasn’t as thorough as I’d hoped it would be. Tough paint job. Quote Link to comment Share on other sites More sharing options...
WoodFireMetal Posted August 24, 2019 Author Share Posted August 24, 2019 I went ahead and used a 80 grit flap disc on the anvil and lightly dressed the edges and face, to some extent. As much as I would love a perfectly flat top, I didn’t want to remove much metal. Got most of the blue paint off, but it’s still buried in the pits. I also took a grinding disc and got as much of the old weld off the shoulder and flattened it, as best I could. Is there anything further I can or should do? Is this enough of a stake to hold it tight in a stump? Should I pre-drill and chisel square a hole to make it less lightly to split open the stump? Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted August 24, 2019 Share Posted August 24, 2019 I think the stake is long enough to hold fine. Drill the hole a little undersized and drive the stake in for a tight fit. I wouldn't chisel it square the stake will take care of that and hold tighter. Another way to mount it would be to put a plate (like a Pexto plate) on the stump with the hole cut to fit the base of the stake. Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted August 25, 2019 Share Posted August 25, 2019 Spike is fine; adjust the height of the anvil face by changing the thickness of the stump it sits in . I started mine stump's hole by drilling a round hole undersized and then forging a slightly undersized duplicate of the stake and used that to burn the hole to fit. Again slightly undersized is good as the char will wear off with use. Quote Link to comment Share on other sites More sharing options...
