jayco Posted July 13, 2008 Share Posted July 13, 2008 Here's a hardy tool idea I've used from time to time to improvise tools I didn't have. It starts with the idea that a piece of 1/2 in. round stock........doubled back on itself fits diagonally in a 1 in. square hardy hole pretty easily.......and it is unnecessary to weld it. The first pic is one of my fullers and a little bending fork. Following that idea, I decided to try making a bottom tool with the same kind of post. I took a piece of 1/2 in. round about 16 in. long and heated about half of one end. I doubled back 2 or 3 in. to make the post........drove it in the hardy hole hot, and bent the rest of the rod down to the face of the anvil with a hammer while it was still quite hot. I made sure it laid right down the center of the face so it would rest solidly. I wanted to try some different swage/fuller shapes on this thing. From left to right; A 3/8 in. half round swage A hot cut A 3/8 in. half round fuller A fuller in a 1 in. arc The first three tools work o k........but I made the fuller on the end useless. It hangs over the step of the anvil......got excited.........forgot to measure! I hot-swaged the first one, and shaped the rest with the bench grinder. The last pic shows the tools in better detail........had to take it outside to get a good picture! Yeah, I know,........TOO MUCH TIME ON MY HANDS! James Quote Link to comment Share on other sites More sharing options...
Finnr Posted July 13, 2008 Share Posted July 13, 2008 Slick James! That anvil looks like a twin to mine. Edge damage inexactly the same place! Someday I'll get around to fixin' that! Finnr Quote Link to comment Share on other sites More sharing options...
jayco Posted July 15, 2008 Author Share Posted July 15, 2008 Thanks, Finnr As to anvils, mine was old and well-worn when I got it. There's not a square edge on the face anywhere. I have a couple of 'blocks of iron' with sharp corners to use for sharp edges on forgings. I can arc weld a little, and I've thought about attempting a repair on mine....... but the rounded edges and missing chip don't really affect my forging, so I just use it 'as is'. And, if I don't do the repair correctly..........I might make it WORSE! So, I'm just gonna leave it alone.....and use it. Quote Link to comment Share on other sites More sharing options...
