arftist Posted July 11, 2008 Share Posted July 11, 2008 Fabbing up a medium end indoor railing today. Often mig weld, them spend lost of time cleaning up. Always wondering if I should spend more time welding(tig), and no time cleaning. So today, I sprayed some mig filler in there, then went over it with tig, fusion only, washed the welds around, beautiful result, no clean up at all. Yes I use anti-spatter spray, etc, but nothing looks as good as tig. Quote Link to comment Share on other sites More sharing options...
Ten Hammers Posted July 11, 2008 Share Posted July 11, 2008 Just a note. I frequently stick stuff together with MIG and then hit the weld with torch and forge the weld ( this is for production stuff I do ). You can also mig it and then hotfile it to smooth ( if not a place that can be hammered). Wish I had a tig rig. I use acetelyne to smooth the weld in the same procedure though. It will scale more and have a larger heat zone but procedure works well. Quote Link to comment Share on other sites More sharing options...
welder19 Posted July 11, 2008 Share Posted July 11, 2008 Are you trying to get rid of the weld bead to get a forge welded look, or just trying to get a better looking bead? welder19 Quote Link to comment Share on other sites More sharing options...
arftist Posted July 12, 2008 Author Share Posted July 12, 2008 I just wanted a better looking weld. Ten Hammers, if you have a dc stick welder, you can get set up with a gas cooled tig torch, and a little juction block (can't remember the right term for it), argon hose connects to one side, torch to the other side, and weld current, and scratch start tig all you want. Make sure you get a torch with a gas shut off valve built in. Should be around $200. Of course you will also need tungsten, filler rods, an argon regulator or flowmeter, and an argon tank. Quote Link to comment Share on other sites More sharing options...
