racer3j Posted July 6, 2008 Share Posted July 6, 2008 First time I tried to light the Baby to cook the ITC. With regulator backed all the way off and forge valve closed, when I crack the tank, it pegs the gauge and shuts down flow. The tank is fine with my bigger gasser. So, what's the deal here?mike Quote Link to comment Share on other sites More sharing options...
Dave Hammer Posted July 6, 2008 Share Posted July 6, 2008 Try closing the valve at the forge, openng the regulator just a little, opening the tank valve, wait a few seconds, then crack the forge valve just a little to light it. Quote Link to comment Share on other sites More sharing options...
racer3j Posted July 6, 2008 Author Share Posted July 6, 2008 Thanks, I will try that-outside of the garage.mike Quote Link to comment Share on other sites More sharing options...
PJ234 Posted July 7, 2008 Share Posted July 7, 2008 Could the regulator be installed backwards? If not, maybe close the tank, back off the regulator, and vent the forge to release the pressure in the lines and start over again. Quote Link to comment Share on other sites More sharing options...
racer3j Posted July 7, 2008 Author Share Posted July 7, 2008 I'll bet I put it together backwards. I'll check later- it is the kind of bonehead thing I would do - not always, but not a rarity either. mike Quote Link to comment Share on other sites More sharing options...
racer3j Posted July 7, 2008 Author Share Posted July 7, 2008 Backwards it is, YESSIRREE! Thanks, it was grinding on me.Mike Quote Link to comment Share on other sites More sharing options...
PJ234 Posted July 7, 2008 Share Posted July 7, 2008 I'm still a newbie, but the first night of a class I recently took gave me an experience similar to the one you described above, and it turned out that the regulator had been installed backwards in that case. We just swapped it out for a different one and went to work, so I don't know if this causes any permanent damage to regulator and/or gauge. Good luck! Quote Link to comment Share on other sites More sharing options...
