Hojjat Posted June 14, 2019 Share Posted June 14, 2019 Does anybody have an idea about the heat treatment cycle of H13? I need to know; 1- Optimal cooling rate for the Die with dimensions of 400*400*400 mm 2- Exact annealing and tempering times and temperatures Thanks Link to comment Share on other sites More sharing options...
Steve Sells Posted June 14, 2019 Share Posted June 14, 2019 H13 Harden from 1800°F - 1890°F (982°C – 1032°C) in air. HRC 52 Annealing Heat at a rate not exceeding 400°F per hour (222°C per hour) to 1575-1625°F (857-885°C), and hold at temperature for 1 hour per inch of maximum thickness; 2 hours minimum. Then cool slowly with the furnace at a rate not exceeding 50°F per hour (28°C per hour) to 1000°F (538°C). Continue cooling to ambient temperature in the furnace or in air. Link to comment Share on other sites More sharing options...
Please sign in to comment
