nitro Posted June 27, 2008 Share Posted June 27, 2008 This may be stupid but, After edge quenching do you temper and if so how would you temper it. Thanx for the info Eric Knight Quote Link to comment Share on other sites More sharing options...
Robert Mayo Posted June 27, 2008 Share Posted June 27, 2008 You must temper any carbon steel after hardening. I put it in an oven at the right temp for the steel and the intended use. If you need more info you will have to give us more info as to what type of steel you are using and what the knife is intended for. Bob Quote Link to comment Share on other sites More sharing options...
