Jake From State Farm Posted February 13, 2019 Share Posted February 13, 2019 My front burner works pretty good the back burner spits and sputters. I’ve cut a hole in the back thinking it needed more air. But it still sputters. After a few minutes, the flame will come up either burner hole sometimes it’ll come up both of them. Any tips would be greatly appreciated. 57171079520__FD250D2C-F444-47D8-BDAC-F6F170C530E4.MOV Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 13, 2019 Share Posted February 13, 2019 Welcome to IFI... Have you read this yet? READ THIS FIRST It will help you get the best out of the forum. I'm sure the burner gurus will need more information on your setup to give you an idea whats wrong. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted February 13, 2019 Share Posted February 13, 2019 1 hour ago, Jake From State Farm said: My front burner works pretty good the back burner spits and sputters Actually, both burners are in terrible shape; one is just working worse than the other. Those green flames mean that they are HEAVILY reducing, and pouring out carbon monoxide, but not much heat. You are getting chimney effects in running burners, because they are running so weak! On the other hand, you seem to have constructed the forge okay, and large burner problems, more often than not, come from small construction boo-boos So, strip the burners out of the forge and prepare to change them. You can start by sending a photo of one of the burners--not running please--so why can get clued in on why it went wrong; it probably won't be any big deal. Quote Link to comment Share on other sites More sharing options...
Jake From State Farm Posted February 13, 2019 Author Share Posted February 13, 2019 Thank you for the info I will get back to you with pictures as soon as possible Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted February 13, 2019 Share Posted February 13, 2019 Okay, the problem with your burners is their design. Do you have a rotary tool (small electric die grinder)? You can purchase one cheap on eBay or buys an import. Forget paying extra for more than one speed. Also buy a couple of 3" thin cutoff wheels for it. Then cut away the steel between the air holes, turning them into slots; that shoild turn your burners into something decent. You can do more with them if that isn't enough, but lets start with just that change, and see how it works out. Note: to get a good rotary tool cheap on eBay, look for a perfectly good used grinder that is only single speed; these are going dirt cheap because people want to be able to adjust tool speed, and are replacing their strong old rotary tools with weak new ones, instead of buying a separate $20 controller for them Quote Link to comment Share on other sites More sharing options...
Jake From State Farm Posted February 14, 2019 Author Share Posted February 14, 2019 Here are the pictures of the burner taken out. Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted February 14, 2019 Share Posted February 14, 2019 I think the holes above the mig tip are a big problem. Seems to me the propane would exit there and burn without going through the tip. I've never seen a burner like that and could be wrong. What design burner is it? Quote Link to comment Share on other sites More sharing options...
Jake From State Farm Posted February 14, 2019 Author Share Posted February 14, 2019 I honestly have no idea. My cousin built the burners. I’m assuming it’s all custom. I have looked everywhere for this style burner and cannot find anything like it Quote Link to comment Share on other sites More sharing options...
Jake From State Farm Posted February 14, 2019 Author Share Posted February 14, 2019 Also the holes in the mug tip are filled in Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted February 14, 2019 Share Posted February 14, 2019 You aren't going to find "anything like it" either; its a conglomeration of different burners, and not all that bad a job either. To changing the air openings I will add filing a taper on the MIG's end, and increasing the taper on the flame retention nozzle a little more, or using one of step nozzle designs. But if you don't start by changing the air openings, none of the other things will help you enough. Quote Link to comment Share on other sites More sharing options...
Jake From State Farm Posted February 14, 2019 Author Share Posted February 14, 2019 I got my lines marked. will cut it tomorrow and post when I get it done. Thank y’all for the info it’s been very helpful. Quote Link to comment Share on other sites More sharing options...
Mikey98118 Posted February 14, 2019 Share Posted February 14, 2019 We're not done just yet. Post your results, and the photo will show us what more you need to do; maybe nothing, wouldn't that be nice? Quote Link to comment Share on other sites More sharing options...
