Di-Acro 1A Bender
Hi folks, I recently picked up a Di-Acro 1A bender in nice shape, but missing its locking pin, the one with the eccentric on the bottom to clamp in your stock when you start the bend.
Does anyone have one of these that they could take some dimensions off of?  Specifically, what the large diameter is, and what the offset of the eccentric pin is?  Napkin-CAD or a pic and some notes would do the trick.
That's a fair question, and the factory is the first place I went.  They want 53 dollars.  That's entirely too much money for a 4" or so steel pin with an eccentric turned on one end.
Yes if you have the equipment to make one - Although machining and heat treating - it isn't bad, and it fits the first time.
As it happens, I do have the equipment, but not the dimensions.
Still seeking the dimensions of the locking pin from anyone who might have one.
Thanks all.
