Champion A 40 issues?
Well I know you guys aren't fans... ha fans... of youtube but I couldn't get a better description for you all...
The first thing I hear is it's running dry. They use a splash oiling system and mounted like you have it the gears won't pick up the oil to lube the other gears & bushings. They were designed to mount vertically not laying on their side. What are you using for lube?
Good Morning,
Every machine needs lubrication. Moving parts must have a film of oil. Shafts and bushings are splash lubricated. Any engine oil is sufficient, no specific weight or Grade.
The way the blowers are set up, there is a reservoir space below the shaft height. The shafts do not have seals, if you overfill, it will leak out. You can cut a plastic oil bottle side open, now you can catch the drippins'.
Enjoy your learnin' curve.
Neil
I didn't have bar oil so I shot for att fluid. Now it just hums beautifully. Still sideways tho. Lol, I'm not sure where to put it vertically.
