March 28, 200818 yr I have a oxygen unit or cutting torch when someone else use torch unit they don't shut off the knobs by the regulators but they shut off by the torch units I know you are suppose to shut off the valves by the regulators but it drains both tanks is there possible a problem with the torch.
March 28, 200818 yr Sure - one or both of the torch valves could be leaking. You might consider requiring whoever is using your torch to shut off the tanks every time they use it.
March 28, 200818 yr I had the same problam , use liqued soap and a fine brush to fined the ''leack place'' and repair NO problem after. Hofi
March 28, 200818 yr this go's for anyone that use any type of gas AC/OX-Propane-Argon-CO2 or whatever soap test for safety & cost of leaks from one end to the next end that mean's ALL fitting & hoses & regulators also the tank valve and seal I can't tell you how many bad leaking tank valve's I have turned back to the supplyer just take's a scrach in the brass seal and you lose $ or is un-safe SO CK IT !! I do & every tank change and ck all hose's @ lest twice a year or more PS--this info come's from a full time weld/smith shop Be safe
