Surgo Posted November 5, 2017 Share Posted November 5, 2017 I understand that people generally cure satanite in their forges first by letting it air dry for a few hours, followed by cycles of firing the forge. My question is around that initial air dry. I'd like to put the forge together this winter. It'll be a standard wool + satanite + ITC-100 combination on the inside. However winters up here can get pretty cold, and this winter especially it's supposed to be a real whopper. There's no kind of heating where I'll be doing the forge (my garage). Given that it's likely going to remain below the freezing point for most of the winter, that air dry step won't be possible. Has anyone else had success skipping the air dry and immediately starting the firing cycles? Or have you found that air dry step to be essential? If it makes a difference, I suppose I'll be waiting for the spring to finish the forge. Quote Link to comment Share on other sites More sharing options...
swedefiddle Posted November 5, 2017 Share Posted November 5, 2017 Good Morning, Surg Plug a light bulb/trouble light inside, Don't let the bulb rest on the floor. Don't block the ends completely, allow some air movement but keep the wind out (allows the warmth to stay in the firebox). Mother Nature will work her miracles. Welcome aboard, neil Quote Link to comment Share on other sites More sharing options...
Irondragon Forge ClayWorks Posted November 5, 2017 Share Posted November 5, 2017 You do need the Satanite to air cure before firing it and the light bulb will do the trick. Another thing is you will be wasting your money with ITC-100 Plastix is a lot less expensive and works better in the forge. Quote Link to comment Share on other sites More sharing options...
Surgo Posted November 5, 2017 Author Share Posted November 5, 2017 Thanks for the light bulb tip! I'd have never thought of that. I'll have to go dig out one of those old incandescent, hah. Also thanks for the tip on Plastix! Spending a lot less money to get something better is the best feeling in the world. Quote Link to comment Share on other sites More sharing options...
