woodforge Posted February 22, 2008 Share Posted February 22, 2008 Hi, I am new to forging and have a peter wright 85 lb anvil which has a bit of a sag in the middle. It looks like it was beaten down enough that it sagged down like a worn out horse. It probably has a sag of 1/4" in the middle and goes gradually up toward the ends. The edges aren't that great either but okay. I read the anvil refacing BP but it appears to be concerning edges only. So my question is what can I do to fix this-- if anything? Thanks Woodforge Quote Link to comment Share on other sites More sharing options...
Rich Hale Posted February 22, 2008 Share Posted February 22, 2008 If it were mine I would do nothing about the sag. It is easier to straighten anything an a surface that has a low spot you can push the high spot of the work down into. The piece will bounce back a bit and it will help you. The surface should be smooth but the sag I would leave. I do not like sharp edges on my anvils. I do like them clean and with different radius's in differnt places,,Near the step I have a small radius, like less than one eigth inch near the heel a bit more. and the end of the heel I leave very little radius for the odd times I use that. Pw's are nice anvils. enjoy. Quote Link to comment Share on other sites More sharing options...
