swamary Posted April 2, 2017 Share Posted April 2, 2017 I have an old snow blower blade. Does anybody know if that would make decent steel to practice making a knife? Quote Link to comment Share on other sites More sharing options...
ThomasPowers Posted April 2, 2017 Share Posted April 2, 2017 Is it your belief that every snowblower manufacturer for the last 50 years have all used the same alloy for their blades? Not a bet I would take! Anyway "junkyard rules" apply: you have to test an unknown alloy: First do the spark test and then do the heat-quench-break test. They should tell you if it's blade worthy steel and start you down the road to testing what heat treat it needs. If you don't want to test---buy known steel! Quote Link to comment Share on other sites More sharing options...
swamary Posted April 2, 2017 Author Share Posted April 2, 2017 1 minute ago, ThomasPowers said: Is it your belief that every snowblower manufacturer for the last 50 years have all used the same alloy for their blades? Not a bet I would take! Anyway "junkyard rules" apply: you have to test an unknown alloy: First do the spark test and then do the heat-quench-break test. They should tell you if it's blade worthy steel and start you down the road to testing what heat treat it needs. If you don't want to test---buy known steel! Thanks, I will do those tests before I use it. Quote Link to comment Share on other sites More sharing options...
